calliper rattle
Author Topic: calliper rattle  (Read 5311 times)
Offline fangstang
calliper rattle
« on: October 27, 2010, 08:54:43 pm »
hi anyone know where i can get a set of anti rattle clips for my front brake pads on my 72 mustang?.
the rattle drives me crazy,i know its the pads in the calipers as it goes away when i place my foot litely on the brakes.
ive tried to get the clips but run into a dead end every time?.
has anyone had any luck with any other fix on this matter?:feedback:
Offline jas24zzk
calliper rattle
« Reply #1 on: October 27, 2010, 09:00:00 pm »
There is also anti rattle paste available.  Most brake joints will have some, else RiPCO or similar.
Jas
Offline fangstang
calliper rattle
« Reply #2 on: October 27, 2010, 09:54:28 pm »
Its a anti-squeal paste not anti-rattle, i looked into that today ,but thanks for the reply jas24zzk
calliper rattle
« Reply #3 on: October 27, 2010, 10:34:20 pm »
 Probably the same as falcon, try mustang autoparts in Bris. Robin has falcon and mustang parts. It may be the pin grommets if the are like xy brakes.
Offline 66ROX
calliper rattle
« Reply #4 on: October 27, 2010, 10:41:33 pm »
If you get the orange one in a semi opaque tube made by CRC(by memory) it sets like a sticky soft rubber and can be used to "hold" the pad to the piston thus stops the rattle, as Jas suggested, caused by the disc flicking the pad around.  You may need to machine the rotors too if they are warped or thickness varies to much.
The springs usually work better if you can get them. Sometimes you need both the spring and stick the pad.
Offline ponyride
calliper rattle
« Reply #5 on: October 28, 2010, 12:14:50 am »
Quote from: fangstang link=topic=12673.msg132848#msg132848
Do they rattle when you go over slight bumps, with your foot off the brake pedal, but don't rattle over bumps with your foot on the pedal?
If so I had the same problem and found the culprit, I posted it here. Let me know and I'll find the post.
Rick
Offline jas24zzk
calliper rattle
« Reply #6 on: October 28, 2010, 12:27:57 am »
Quote from: 66ROX link=topic=12673.msg132868#msg132868
Thanx for the backup.
Anti Rattle and Anti squeal are different products.
Jas
Offline fangstang
calliper rattle
« Reply #7 on: November 03, 2010, 09:11:02 pm »
yes it only rattles over bumps with foot off pedal and goes away with foot on pedal,
ive tried looking for the anti rattle clips at our local wreckers F100 have the same clips fitted as the pads are similar to the ones on my 72 but not exactly the same i found one clip but still need another (anyone wrecking a F100 or Bronco with disc brakes that i can get a anti rattle clip off?
i tried matching up the pads at Better Brakes and Brakemart in town but they dont exist,then i searched the net but all other 71-73 mustangs dont have the same pads as i have?,
does anyone have pics of there 71-73 mustang front brakes?
Offline ponyride
calliper rattle
« Reply #8 on: November 03, 2010, 11:20:29 pm »
Check the thread below fangstang. Have a look at your caliper and see if it's the same as this on my '70. If the rubber "insulator" is missing/broken off yours then that's the problem. Grab the whole assembly and see if it clunks as you wriggle it. I got new insulators for mine and hey presto! Problem solvered. Advice compliments of ozbilt.
http://mustang.org.au/forum/viewthread.php?tid=11205#pid117086
Rick
Offline fangstang
calliper rattle
« Reply #9 on: November 04, 2010, 08:37:59 pm »
thank you ponyride but my brakes dont use pins they are the same as F truck
Offline fangstang
calliper rattle
« Reply #10 on: November 04, 2010, 09:02:21 pm »
ill get a pic so you can see what my problem is, i cant get any clips as the cars got older the clips were thrown away with the old pads?:cry:
Offline fangstang
calliper rattle
« Reply #11 on: November 04, 2010, 09:18:58 pm »
this is what the clip looks like on my 72 mustang
Offline EXHAUSTED
  • Nearly retired
calliper rattle
« Reply #12 on: November 04, 2010, 09:44:24 pm »
Another method to compensate for the clearance is to mig weld one end of the pad backing plate & file down to suit so that is a snug fit in the caliper. I might have some old clips at my workshop. I'll check tomorrow. Most brake specialists should have something laying around!!!!
calliper rattle
« Reply #13 on: November 05, 2010, 01:19:34 pm »
Maybe fit some XF calipers if the bolt pattern is the same.
Offline EXHAUSTED
  • Nearly retired
calliper rattle
« Reply #14 on: November 05, 2010, 08:19:13 pm »
Found some. U2U me if you want them!!
Offline fangstang
calliper rattle
« Reply #15 on: November 06, 2010, 01:29:17 am »
EXHAUSTED just u2u you about the clips,thanks for that
