tachometric relay or fuel pump safety switch where can I get one???
Author Topic: tachometric relay or fuel pump safety switch where can I get one???  (Read 9468 times)
Offline VIBE 65
    • www.vibephotography.com.au
I have recently fitted a holley blue fuel pump and its wired through ign circuit via relay. Ive done some research and as a safety thing im after a tachometric relay. It need coil pulse to send signal to fuel pump relay so in the event of a crash and im knocked out the fuel pump will stop as soon as engine stalls. As it is fuel pump runs whenever ign is on.
Problem is while in google land everyone says just go to a local auto elec and they will have one for $20 buck ish or go to a wreckers. I went to 3 auto elecs yesterday plus repco and bursons and no one knew anything about them or where to get them. So does anyone know where I can get one or if I go to wrekers which cars run them and where they are in car. I think maybe VL commodores  had them???
Offline jas24zzk
« Reply #1 on: September 02, 2010, 12:57:01 pm »
Just use an LPG safety switch.
Does EXACTLY what you want it to.
No signal from the coil, so it turns off the flow of LPG in the event of an accident.
Jas
Offline VIBE 65
« Reply #2 on: September 02, 2010, 01:51:57 pm »
Thanks Jas, will make a call today!!!
Offline moose17
« Reply #3 on: September 02, 2010, 03:18:13 pm »
try ashdown-ingram the part number is fpx058 or repco will be able to get as well
Offline tim_morrison82
    • http://s806.photobucket.com/home/tim_morrison82/allalbums
« Reply #4 on: September 02, 2010, 05:32:10 pm »
cool, sounds simple. wouldn't all cars these days have these fitted? or is it still just LPG?
most cars these days you can hear the fuel pump buzzing away with ignition on... i'd hope they would do the same be it LPG or otherwise?
Offline gary70au
« Reply #5 on: September 02, 2010, 05:41:35 pm »
Found this on ebay
Safety switch
Offline VIBE 65
« Reply #6 on: September 02, 2010, 07:26:28 pm »
thanks guys, I called a local LPG guy and he has one for $45 I thought they would be about half that but maybe not. Found the same one on ebay which is what I need just too dear.
thanks moose I might give repco a call and see if they can get it and how much it is to see if I can save a few bucks.
hey Tim I think alot of new cars control this through the computer but in saying that our rav4 you can hear it with ign on but its very quite not like the holley I have (reminds me I have to try and rubber mount it to reduce noise).
At least I have a few leads on where to get them now. Out of curiosity what does everyone else do , do they have this setup if running a elec fuel pump or are you just happy with it running whenever ign is on??
Offline A67PNY
« Reply #7 on: September 02, 2010, 07:50:01 pm »
Hey VIBE 65
I am pretty sure I have one of these switches under my house
along with other gas bits.
If you like I can have a look tomorrow.
If it's there you can have it.
I have no use for it.............
Vlado
Offline VIBE 65
« Reply #8 on: September 03, 2010, 09:47:43 am »
Yeah Vlado, Let me know if you have one that would be great.
Thanks,
Justin
Offline A67PNY
« Reply #9 on: September 03, 2010, 12:34:37 pm »
Justin
I take it this is what you are after.
If so send me your details...
Offline VIBE 65
« Reply #10 on: September 03, 2010, 02:16:38 pm »
Thanks mate,
U2U sent
Offline A67PNY
« Reply #11 on: September 03, 2010, 03:39:51 pm »
Oh forgot to mention
That switch comes whith a no return guarantee.
Its in the mail.
Cheers............:thumb:
Offline VIBE 65
« Reply #12 on: September 03, 2010, 06:02:07 pm »
:smile01: I was hoping you could drive up and fit it for me??
Thanks for your help. If your ever up this way with your car ill see if I can get a few photos of your car for you as a thankyou. Or if im down that way with my gear can do the same.
Thanks again! :thumb:
Offline donoauto
« Reply #13 on: September 04, 2010, 07:58:58 am »
Yeah , don't touch the ASH/ING. fpx058. Just checked it out , my trade buy price is $198 !!!!!! Suggested retail of $347. Must be wrong , it can't be that expensive. Definitely the LPG relay is the go.
Regards ,
    Mark.
Auto-electrician & car A/C guy.
« Reply #14 on: September 04, 2010, 10:21:38 am »
You can get push to reset ones out of old jags at the wreckers, Discos have similar one  just to the right of the console under the dash.
Offline VIBE 65
« Reply #15 on: September 07, 2010, 07:56:44 pm »
Thanks A67PNY got the switch in the post Monday. Will fit it up 2moro hopefully.
Thanks again mate :thumb::thumb:
Offline TimR67
« Reply #16 on: September 07, 2010, 08:01:19 pm »
Quote from: shaunp link=topic=12121.msg128363#msg128363
Where are they in the Jags, Ive got a series 2 XJ6 in the back paddock, I might pull it out and put it in mine
Offline A67PNY
« Reply #17 on: September 07, 2010, 09:27:31 pm »
Quote from: VIBE 65 link=topic=12121.msg128710#msg128710
No problem VIBE glad to help...........:thumb:
« Reply #18 on: September 08, 2010, 10:55:41 am »
Quote from: TimR67 link=topic=12121.msg128712#msg128712
Try the left hand kick panel from memory, it's behind a black plastic cover next to the door jamb. Just below the dash
