Craig,
hard to say what your on about, but i will hazard a guess.
I am assuming you are talking about the insulator between the steering box and steering shaft. ?
Compare the pic in this link:-
http://www.jasonpigdon.com/storage/Budgies196.jpgIf so, there should be 2 pins, one large and one small. Then two special bolts, with special washers in place. Hard to describe, but once you know what you're looking at........
If I have guessed you correctly, go take a look at the installation on and XF at the wreckers. You will see the special bolts etc. Probably wise to get them while you are there :)
Hope this helps
Jas
