does anybody know what should be used to re glue the chrome around the windscreen of a 67? its started to lift and there is several chips in the paint that go all the way to bare metal, what should i use to fix it... will have to get touch up paint made to fill it up... also there is the trim pieces at the bottom edges of the car, how are they removed are the screwed in or glued on?
